It is currently Fri Jul 18, 2025 1:38 am
PostPosted: Fri Nov 10, 2006 11:24 am
First name: Tracy
Last Name: Leveque
State: CO
Michael,
Are you talking about this one?
If so, it already has the same size on each side. Can you post a link to the one you are talking about?
PostPosted: Fri Nov 10, 2006 11:53 am
Michael,
In a post a month or so back I asked Even Gluck about some tools and this was one of them. He has both the 150 grit and 300 grit files. He needed to hog off some material for a specific job so bought the 150 but says he has not used it since, "just too scary" I think were his words, it cuts very fast. He says the 300 grit is all one needs and is on my list for the next order from Stew-mac.
Hope that helps!
PostPosted: Fri Nov 10, 2006 12:08 pm
I use a lot of diamond, esp. when gem faceting/carving/polishing and tool honing, and am apt to make most of my files, points, laps, and so on. One can use various resins, moulding clays (hardenable) and solders to bind loose diamond grit (quite inexpensive*, btw -- 5 carats sells for 8 to 15 dollars and goes a long way), to any number of substrates, and although I've not yet made a fret file, I'll probably give it a try. Nothing wrong with buying one, of course. Just thought I'd mention it -- might be useful to someone.
*I like the slightly more expensive friable diamond powders. One source: http://www.facetingmachines.com/polishes.shtml
_________________________
David Barnett
SW Florida
PostPosted: Fri Nov 10, 2006 12:26 pm
I have the 300 and it is great.
I agree that 2 grit, one size wire would be ideal.
Med fret wire
PostPosted: Fri Nov 10, 2006 2:47 pm
[quote=DBarnett]I use a lot of diamond, esp. when gem faceting/carving/polishing and tool honing, and am apt to make most of my files, points, laps, and so on. One can use various resins, moulding clays (hardenable) and solders to bind loose diamond grit (quite inexpensive*, btw -- 5 carats sells for 8 to 15 dollars and goes a long way),[/quote]
   I used to use laps and diamond polish a lot in the plastic tooling business. Do you have any links to detailed info on the process.
PostPosted: Fri Nov 10, 2006 5:28 pm
I think I've gone through about every fret file out there from Stew Mac and
others, and I still go back to my three corner file for most jobs. I'm
probably in the minority there, but it's what I learned with and still seems
to be the most efficient for me. When I do use the diamond files though,
it is quite rare that I use the course grit. It's very agressive and unless you
have a tremendous amount of material to remove you will usually spend
as much time getting rid of its file marks as it would take to do the whole
crowning with a fine file.
If you are going to have just one double sided diamond file, I think it
would be much more useful to have two crown sizes in 300 grit than
having only one size in 150 and 300. The crowns on the diamond files are
only an approximation anyway, and you will generally have to rock the file
from side to side to get an even crown. A medium crown file is often
much flatter than a medium crown fret, and if you try to shape the fret
straight to the shape of the file you will often get a bit of a corner where
the side meets the new crown. I've had several customers bring
instruments to me for re-redressing to address this problem after fret
dresses from another shop in my area.
If you have to choose just one, go with the 300 grit offset / rounded end
file that you mentioned. The dual grit files that they sell are a great idea,
but I really don't like the shape of the crowns. The narrow is good for
medium, medium okay for jumbo, and the wide crown seems almost flat
enough to level inlay strips on a fretless conversion. The crowns
on the offset file seem a little more agreeable to me, and I find the curved
ends very convienient to work with.David Collins39032.0637615741
